Relevant model
- ILME-FR7
- BRC-AM7
- BRC-X400
- SRG-A12
- SRG-A40
- SRG-X120
- SRG-X400
- SRG-XB25
- SRG-XP1
- REA-C1000
[Summary]
This software is an application for installation and use on a computer. The software allows you to use an RTSP stream
received from a Sony network camera in a computer application (such as a web conferencing tool).
[How to use]
Please refer to Help Guide. Click here
[The verified PC environment]
Supported operating system
Windows 10 64-bit/11 64-bit
macOS 12/13/14/15
CPU: Intel Core 8th generation (Coffee Lake) or later (recommended)
Memory: 8 GB or higher (recommended)
Ethernet port for receiving RTSP stream
Monitor with 1366×768 or higher resolution
